Electrical Front wipers always run at full speed.
Old Sep 22, 2013 | 11:44 AM
zapotek's Avatar
zapotek
If i turn on my front wipers to normal speed, they always run at full speed. Changing to full speed gives no change. Pressing the handle down gives me one wipe at normal speed (as it should). Have replaced the relays, no change. In addition if i use my rear viper, it all goes out of sync. Front wipers goes on after turning them off, and stops at wong positions. The rear wiper does the same thing. Turning the car off and on usually solves that problem.
Any suggestions?
Old Oct 20, 2013 | 05:17 PM
1rstmini05MCS's Avatar
1rstmini05MCS
Check BCU
The Body Control Module behind panel behind the hood release could be causing that problem. If there is any moisture collected in or around it it can cause all kinds of gremlins. There are several other potential causes. If your car is equipped with a rain sensor on windshield it could have a defect or loose connection or it could be the switch on the steering column.
Good luck
Old Oct 21, 2013 | 05:39 AM
zapotek's Avatar
zapotek
Thank you, i will check for moisture, and/or maybe replace the switch on the steering column (have been suspecting this one). There is no rain-sensor.
Old Oct 22, 2013 | 06:25 PM
1rstmini05MCS
Here is a breakdown of the functions and controls that are handled by the BCM/BCU. There is a comprehensive outline for the wiper functions in this PDF that might help you troubleshoot your issue if it still exists.
http://www.bmw-planet.com/lib/mini/B...L%20MODULE.pdf
W0TM8
Dec 19, 2019 07:50 AM
FLYM1N1
Aug 15, 2015 11:20 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
