Suspension Are there any decent lowering springs for pre 3/02?
Old Sep 16, 2013 | 09:37 AM
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
Ive tried H&R and eibach. Looking for a more comfortable ride with my 3 month only production hard to find suspension. Any help appreciated! I have also tried koni shocks and replaced them w stock.
Old Sep 23, 2013 | 04:44 PM
N2MINI's Avatar
N2MINI
How bout coilovers. With the money you have spent and now doing it again you could have had a set. I'm guessing you want to lower it while having a decent ride. People with swift sprints and koni yellows swear by them.
Old Sep 24, 2013 | 05:57 AM
cristo's Avatar
cristo
Alliance Member
You can swap the necessary parts to make the newer suspension fit the older MINI.
Then you can use springs for the 3/02 and later suspensions.
I believe that's the struts, all the upper strut mount parts and the end links, too.
If you go for coilovers, you still need to change the end links since the pre-3/02 ones
mount to a different location than the 3/02 and later ones.
Old Sep 24, 2013 | 06:43 AM
Helix13mini's Avatar
Helix13mini
MINI swapped the old style suspension for the later style as a matter of routine when early cars came in for service, so, unless you never serviced your MINI at the dealership, you probably have the later style. Are you sure you still have that early setup?
Old Sep 24, 2013 | 08:03 PM
GreekDrifter91's Avatar
GreekDrifter91
its been awhile sense i installed them but they are great! i just want to play with the dampening a bi more to find the spot where i like it.
Old Oct 2, 2013 | 03:43 PM
ClintTheMiniOwner
I did not know this! Where is a good place to look for how to change it? Im a do it your selfer. Good info thank you
Old Oct 2, 2013 | 03:56 PM
ClintTheMiniOwner
I just picked up some 16" enkies that I am gonna try for a while. Not as pretty as my 18" racing harts but hopefully improves the ride quality
Old Feb 10, 2014 | 12:43 PM
ClintTheMiniOwner
If I order these parts will it all bolt in? Thanks!
Old Feb 10, 2014 | 07:47 PM
ClintTheMiniOwner
This is what Im up against
Old Mar 7, 2014 | 09:42 AM
hypnotiqphil's Avatar
hypnotiqphil
I think if you swap the spring perches you should be good? I did this when i put r56 struts on my r52 just swapped the spring perches and top hats and it was good to go! And it looks like if you do that you have to change your sway bar end links.
Old Mar 19, 2014 | 06:05 AM
minsanity's Avatar
minsanity
These coilovers @ $420 should be for pre3/02:
http://www.bavauto.com/fland.asp?par...FeY-Mgodbh4Aaw
Old Apr 21, 2014 | 08:25 PM
ClintTheMiniOwner
^Thanks I will give them a call and see.
OutMotoring
Sep 8, 2015 06:27 AM
Suspension Products
Sep 3, 2015 09:41 AM
Llanrhaeadr_Cymru
Country Roads MINIs
Sep 2, 2015 07:12 PM
Sep 2, 2015 11:15 AM
