R50/53 oil change help
Old Oct 28, 2002 | 10:41 AM
coachb's Avatar
coachb
My ly/C is still two months away but it is never to early to get things ready. My mechanic reccomends an oil change at 500 and 1500 miles. I would lile to do it my self but would like to know a couple of things first for those of you that have done it yourselves. Does the Cooper have a skid plate over the oil pan that needs to be removed to change oil? Is the oil pan aluminum that might strip out easy?, do you use a troque wrench?, have you replace washer each time? Finally, where have you got you oil filter, from a MINI dealer or can we get them someplace else yet? Thanks very much. Production date 11/08.
Old Oct 28, 2002 | 11:04 AM
Redbird73's Avatar
Redbird73
Coordinator :: St. Louis MINI Club
I changed the oil on my MCS at 1200 and 5000 miles. The drain plug is very easy to get to (with a shallow pan you don't need to raise the car off the ground). I have used the same gasket for two changes and it still seals tight. I tightened the plug without a torque wrench.
Get the filter from a MINI dealer. I got oil from them as well.
Search the forums for "oil change". There are several good threads with lots of info.
Aaron
Old Oct 28, 2002 | 11:17 AM
coachb's Avatar
coachb
Thanks, sounds fairly simple. Can't wait to "get my hands dirty".
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
patpatpat
Aug 27, 2015 07:51 AM
HaveATank
Aug 24, 2015 10:26 AM
