R56 sunroof seal shot?
sunroof seal shot?
I was looking at my sunroof and noticed a seam that water leaks into, it goes across the whole roof. I washed my car and water does go into this space, is it ok? where does it drain out? heres a photo, its on the left where that dried grass blade is in.
I don't think it gets wet. where are the runners?
If the drains are clogged you will get water near the front and drips on the headliner near the rear-view mirror. If clogged / disconnected. in the back you will get it on the rear headliner or in the trunk
Here is a diagram and list from another thread I posted on:
Check the to cassette where the water drains in the corners. Sunroof drain tubes. They can clog with debris and such. There are two in the front and two in the rear. Also if they are clean and look ok the drain tube might be leaking. You have to get behind the headliner and A pillars to see. Since its in the front you will want to check #2 connection as the problem.
For Gen 2 R55 R56 MINI models , they have they same general set up as the Gen 1. Check the connection at the hose to the tray and also check to see if debris clogged the sunroof tray near the hose connection.
#2 in the diagram
http://www.ecstuning.com/Search/51738197504/
Rear # 3 Water outlet hose rear 272 mm size.
http://www.ecstuning.com/Search/SiteSearch/54107043425/
or
Rear # 3 Water outlet hose rear 739 mm size.
http://www.ecstuning.com/Search/SiteSearch/54137174869/
The seal #8 in the diagram above is in the middle, your does not look too bad, but I cant tell if its fully marking contact on the seal.
Here is the new seal. #8 Part # 54102755851
http://www.ecstuning.com/Search/SiteSearch/54102755851/ES156664/
Thanks and hope that helps.
#2 in the diagram
or
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
