How To Navigation Screen Scratch Fix
Old Sep 12, 2013 | 11:10 AM
04_Indi_Mini_S's Avatar
04_Indi_Mini_S
If you have a Mini with navigation, you may have a screen that looks awful. If it is purple color with what looks like odd scratches and wear, your anti-glare coating has been damaged.
There are two choices. You can live with it, or you can remove the coating. Removing the coating makes the screen more reflective, but I personally found it to be a non-issue and like the way it looks better than a scratched up screen anyway.
To correctly accomplish the coating removal you will need to pull the center dash apart and pull out the navigation unit. If you don’t remove the unit, you will not be able to get into the corners. Pulling the dash apart is well documented, so I will start further in. Remove the navigation from the car by unscrewing the screws that go in the blue circles. After pulling the unit, remove the black cover by unscrewing the 4 screws in the red circles
You now have full access to the screen.
To remove the coating, you can use a mild to light polishing compound. Don’t use a heavy compound or you will permanently scratch the screen. I used Chemical guys v36 for reference. Polish from the edges first since they will be less worn and take more polishing to remove the coating. Go easy using light pressure so you don’t break the screen. When you are finished and put everything back together, this is what you will have.
Old Sep 14, 2013 | 07:57 AM
04_Indi_Mini_S
I was made aware that the images are not showing up. I tried quickly fixing them before needing to leave. Until I can get back to fix them, here is a link to the guide I put together on an external site.
Navigation Screen Coating Fix
Old Dec 6, 2016 | 12:06 PM
HasAnMTBProblem's Avatar
HasAnMTBProblem
Hmmm, interesting. Has anyone tried recoating the screen with spray-on anti-glare coating?
SolCalMini
Sep 1, 2015 08:19 AM
Aug 27, 2015 12:25 PM
nismo4life
Aug 5, 2015 08:31 AM
veevsato
Aug 5, 2015 04:42 AM
