chirping from e-brake - fix?
Old Sep 8, 2013 | 06:26 PM
jeffvdgo's Avatar
jeffvdgo
New (to me) 2010 MCS with an odd problem. At highway speeds, there is a chirping from the rear. Pulling up slightly on the e-brake (less than 1 click) makes it go way instantly. Put the e-brake back down...chirp, lift up...no chirp. It seems like there is a little too much play in the e-brake cable, and tightening up slightly would fix it. I've seen references to the nut under the boot - should I tighten that, or anyone have other ideas? The brakes feel fine to me otherwise, and the e-brake engages fine at higher clicks.
Old Sep 8, 2013 | 08:00 PM
danjreed's Avatar
danjreed
I would not adjust the parking brake.
It sounds more like the rear pads are not fully retracting. I would remove the pads, and calipers and inspect the guide pins... Lube them.. Clean off the pad mounts, add anti-squeal compound to the pad backs..
Should take care of it.
Old Sep 8, 2013 | 08:27 PM
jeffvdgo's Avatar
jeffvdgo
Thanks...guess I need to learn how to do the above!
PsychoRallye
21
Feb 17, 2019 06:08 AM
minimofo
Dec 26, 2015 12:03 PM
gnhovis
Dec 14, 2015 05:31 PM
ericf1993
Sep 26, 2015 03:58 PM
wlfman13
Sep 17, 2015 10:05 AM
