R56 windshield washers not working 07mcs
Old Sep 8, 2013 | 11:59 AM
bdrecksage's Avatar
bdrecksage
I have a 07 mcs. the front windshield washers stopped spraying. the rear still works. WHen I engage the front i dont hear anything, when i engage the rear i hear the pump. I check the owners manual for a location of relays or fuses and didnt find anything. I found a fuse on the passenger side interior that looked like it would be for the washers, but the fuse was good.
anyone have any ideas?
Old Sep 9, 2013 | 11:45 AM
Here is the diagrams and the parts to check.
#3 is the double pump washer which control the front and rear.
http://www.ecstuning.com/Search/SiteSearch/67128377987/
#5 is the headlight washer pump.
Check the hose connect from the hood to the double pump down in the tank, tank is on the driver side engine bay and goes into the front driver side bumper area.
#3 is the hose runing to the hood nozzles. You could have a clog in the system there by the little valve in the center of the Y.
Windshield Washer Cleaning Hose
http://www.ecstuning.com/Search/SiteSearch/61667220827/
Also check the nozzle themselves, you can try cleaning out the heads with a pin as they can get clogged at the tip of the nozzles.
Windshield Washer Nozzle - Left
http://www.ecstuning.com/Search/SiteSearch/61662755722/
Windshield Washer Nozzle - Right
http://www.ecstuning.com/Search/SiteSearch/61662756194/
You can try cleaning them first then checking the rest of the system.
Thanks and good luck.
W0TM8
Dec 19, 2019 07:50 AM
mini-medic
Aug 18, 2015 09:13 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 14, 2015 07:12 AM
