normal engine noise??
Old Sep 6, 2013 | 12:41 PM
locksleyr53's Avatar
locksleyr53
is this a normal sound for the engine? its an 03 hardtop S and I have had it for about 8 months now and I'm pretty sure it has always sounded like this. I've never heard an engine make a rattle/chatter like that.
http://s86.photobucket.com/user/Anbu..._1514.mp4.html
Old Sep 11, 2013 | 06:16 PM
screwed36coupe's Avatar
screwed36coupe
hello. i hope someone can offer advice to what that sound is. mines doing the same thing and i dont think its a valvr. i opened the valve cover,oil cap, and the noise didnt get louder. it comes and goes, when its cold or hot driving fast or at idle. in nuetral, in gear. no clue...
Old Sep 12, 2013 | 02:42 PM
mrbean's Avatar
mrbean
I don't hear anything glaringly abnormal, but it kinda sounds a little more "clicky" then it should. A few things to think about.
-The dual mass flywheel can be very noisy. The sounds can come and go. If you push on the clutch does it get better or worse?
-A bad valve lifter? But, the frequency of clicks at idle sounds a little too fast to be valve train noise to me.
-Fuel injectors. Yes, they make noise. Some engines just have loud injectors. My MKII Jetta Digifant sounded like sewing machine when you stuck your head under the hood. It was completely normal (I've owned several of them over the years).
-Belt tensioner and/or crankshaft pulley. Very common failures on these cars that usually coincide with weird clicking noises. Most noticeable when the engine is under load.
-Timing chain.
Take a ~3ft length of rubber hose and use it as a makeshift stethoscope. Stick one end in your ear, grab the other end and fish it around the engine bay to pinpoint the location of the noise.
Old Sep 12, 2013 | 05:52 PM
locksleyr53
-Timing chain.
I do get a noise that goes away when I push my clutch in, my throw out bearing but this is different. This noise comes from the passenger side of the engine compartment so that could be a pulley. I'm an auto tech student and asked my engines instructor, he said it could be valve timing too.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
tylewis
Aug 18, 2015 06:53 AM
damncajun
Aug 17, 2015 08:25 PM
stellaherself
Aug 14, 2015 05:28 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
