R52 I knew I shouldn't have...
Old Aug 29, 2013 | 07:57 AM
HyTech's Avatar
HyTech
From: Part year in Portland OR, part year Kalamazoo MI
... taken it to the dealer (it's year old dealership and they seem clueless). Top wouldn't go down (light flashes, motor whirs)and sunroof worked fine. I wanted the top checked so off to the dealer 'service' department I went. $300 and a week later they don't know what is wrong with it, but for a starting price of $2,000 they'll work on it. Yeah, right! And the kicker is - the sunroof doesn't work anymore, just clicks every half second or so, no movement. I knew I shouldn't have taken it to the dealer.
Old Aug 29, 2013 | 08:09 AM
mitch171's Avatar
mitch171
I have not had as bad of an experience, but a new dealer came closer to where I live. They seem to know very little about first gen. models.
Old Aug 29, 2013 | 11:17 AM
What year is your Convertible, and what are the symptoms? Do you have pics or a video. I might be able to help you.
Old Aug 29, 2013 | 06:07 PM
HyTech's Avatar
HyTech
Thanks for the fast reply. It is a 2005 made in 09/04 and is a base, non-S model. Sunroof; I press the button and it clicks every half second or so and there is no discernible movement, and it doesn't seem as if the latches release. (Are the latches hydraulic?) The top, I press the button and the red light flashes and motors whir smoothly, no clicking or jerking and no mechanism movement at all and latches don't seem to release.
Personally, I don't care if I have a power top or not so do you think it may be able to converted to manual folding, provided I get the sun roof part and latches working? This is the most electronic/automatic car I've owned, I like things manual.
Old Aug 29, 2013 | 06:10 PM
HyTech's Avatar
HyTech
Top
Thanks for the fast reply. It is a 2005 made in 09/04 and is a base, non-S model. Sunroof; I press the button and it clicks every half second or so and there is no discernible movement, and it doesn't seem as if the latches release. (Are the latches hydraulic?) The top, I press the button and the red light flashes and motors whir smoothly, no clicking or jerking and no mechanism movement at all and latches don't seem to release. A video wouldn't help as there is nothing to see happening.
Old Sep 3, 2013 | 11:46 AM
Thanks for the information.
So the convertible top is completely closed and you are getting the clicking noise on top of the red flashing light?
The front latches that unhook the top work right before the top begins to go back toward the trunk.
There is a motor located in the diagram #7. It pulls the cables back which opens the sunroof posrtion. Then when you press the open button again and hold it the the top moves back (sunroof) an inch or two and the front hook unlatch, and the top goes completely back, the back portion of the top runs on the hydraulics and you can hear them, the pump. The front portion is motor and cables.
Old Sep 8, 2013 | 10:31 PM
DocRock's Avatar
DocRock
Similar 'help'
I had similar situation; sunroof opened to open position okay; when pushed button again, sunfroof moved back about an inch, open latches and then stopped without triggering hydraulic motor. Local BMW shop thought they could help, but ended up with sunroof that wouldn't open but could hear electric motor spinning; Local Mini shop then replaced electric motor and drive cables.
Now sunroof and top ALMOST operate fine. Critical problem is that the sliding part inside the sunroof assembly that drives the unlatching of the front hook is now broken on the passenger side. See pictures. Does anyone know if this part can be removed and replaced or repaired?
File Type: pdf
Old Sep 22, 2013 | 07:03 PM
HyTech's Avatar
HyTech
Update on the top. My drive to Oregon is over so now I have time to attend to the issue of the non-working top. I have no video because there is nothing to see because nothing happens. First, I checked all the fuses and found them OK, though I didn’t meter them. When I press windows down/up switch the back and front windows do as they are told. When I press the top down/sunroof open button the latches move about a 1/2 inch (is that enough?) and the sunroof motor whirs for six seconds or so, then stops. When I press top up/sunroof closed the sunroof motor whirs and the latches move back to the latched position. There is no flashing red light by the switch, though it did flash when the trouble first started. When the trouble started the sunroof would still open and close properly. That was when it was taken to the dealer to diagnose the problem, and $300 later when I got it back the sunroof didn't work and the window seal where the sunroof and top join (you know, that slash) was damaged, the rear section bent outward, as I hope the picture shows. The dealers attitude was, tough luck. I’ll never take anything to the dealer again unless I have no recourse.
Old Sep 30, 2013 | 06:29 PM
HyTech's Avatar
HyTech
Well, progress. Now things are better but top still refuses to open. Now the buttons work OK. First press sunroof whirs but doesn't open. Second press windows drop, latches release and hydraulic pump whirs but top stays closed and red light flashes. Time to pull panels and such like.
Old Sep 30, 2013 | 07:33 PM
ACallahan's Avatar
ACallahan
The only thing I may do at a stealership...er..dealership is maybe buy a car, but that is it unless its free warranty work they will never see me again.
Old Oct 1, 2013 | 11:25 AM
bugeye1031's Avatar
bugeye1031
Moderator
We're out here pulling for you - please keep us updated.....I'm feeling pretty lucky to have a good dealer nearby (Inskip - Warwick RI)
Old Oct 1, 2013 | 12:54 PM
Fly'n Brick's Avatar
Fly'n Brick
Here are a few independent MINI shops not too far from you there in MI. Maybe one of them can help you for a bit less.
http://www.germanautoltd.com/Home.aspx
http://www.communityautomotive.com/
http://www.prestigeimport.com/
http://www.thesharpecollection.com/index.htm
http://www.eurotechofholland.com/
http://www.foreignaffairsmn.com/
Old Oct 4, 2013 | 07:51 PM
HyTech's Avatar
HyTech
Thanks, Brick
FOr your efforts, but I'm now in Oregon for the school year and will buy a Bentley and do it myself. I have access to a friends unused, two car garage. At the worst I have a Mini convertible whose top doesn't retract, but I still have a fun Mini. It really can be folded manually if you're willing to do w/o push button convenience, but it can't be much harder dropping the top than my Miata was. I just have to get the sunroof working.
Old Oct 4, 2013 | 08:14 PM
Fly'n Brick
You are welcome, it was no effort. This info is found on soopercooperinfo.com. I went back and did a cut and paste of the Portland(ia?) independent shops just in case you find yourself in over your head.
http://arautoservices.com/index.php/arautoservices
http://portlandautohaus.net/
http://schollsferryauto.com/index.php
http://www.boydmotorwerks.com/
http://www.madnessmotorworks.com/
http://www.marquemotors.com/
http://www.matrixintegrated.cc/
http://www.mustangmogul.com/
http://www.nweuropeanauto.com/?gclid...FcIFRQod7TR3Bg
http://www.pacificmotorsportsonline.com/
http://www.stevesimports.com/
http://www.thejagshop.com/
Old Oct 5, 2013 | 05:53 AM
HyTech's Avatar
HyTech
again, Brick, and for soopercooperinfo. I'm just getting into Cooperdom (the new ones are so different from my original) after Miataworld. I have to say I like the Mini better. That might be because I've been driving front drivers since the early 70s.
fkrowland
Sep 30, 2015 10:30 AM
Mini ni
Sep 24, 2015 05:42 AM
Klenk
GP Talk
Sep 16, 2015 11:29 PM
