Drivetrain FMIC! OEM VS. Aftermarket
Old Aug 28, 2013 | 07:26 PM
TerminalVelocity's Avatar
TerminalVelocity
After pulling off the grill on my JCW Paceman I was impressed to see a much larger IC than was on my JCW Coupe which utilized that small boxlike IC that all MINIs use. The Paceman IC is about 10" high x 21" across x 1.5" deep. I have a Helix IC that I was planning to mount to the PM (I had it on my Coupe with great results) but seeing as its nearly the same size overall sans the larger lower tank I wonder is it worth it? The OEM IC is actually taller but I don't have any numbers on overall volume.
Any take on this from folks who've been down this road?
Old Aug 28, 2013 | 07:34 PM
chrunck's Avatar
chrunck
Pretty sure you're the first to ask this question. Others with the larger JCW CM/Paceman intercooler have just stuck with that one.
Old Aug 28, 2013 | 07:41 PM
TerminalVelocity
So as far as you know this IC is JCW specific to the CM/PM?
Old Aug 28, 2013 | 08:44 PM
chrunck's Avatar
chrunck
Yep. Doesn't come on the other JCWs to my knowledge.
Old Aug 28, 2013 | 09:44 PM
TerminalVelocity
Just doing a quick look and crude calculation the large OEM IC has a volume of about 300 cubic inches while the Helix is roughly 291. The cooling face of the OEM is 220 to Helix's 178. I can't say for fin density and the differing weight and materials ability to shed heat. The MINI intercooler is made of the same materials as their smaller FMIC.
Old Aug 29, 2013 | 06:28 AM
chrunck's Avatar
chrunck
The biggest problem with the Helix on the Countryman is that a good bit of it is hidden by the front crash bar (I have the Helix, btw). If the OEM unit sits lower so it's directly behind the lower grill, it probably performs better.
Old Sep 6, 2013 | 01:48 PM
TerminalVelocity
Unfortunately no, it doesn't. It actually covers more than the Helix. Crashbar and a significant amount of radiator.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Branto
Aug 11, 2017 05:32 PM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
