R56 diy timing chain, need torques
Old Aug 24, 2013 | 03:34 PM
MiniShini's Avatar
MiniShini
Hi all, I need help. I'm replacing the timing chain on our 2008 r56 and I thought my CD manual had bolt torque specs but I can't find them. I need the following:
Upper chain guide, 2 small bolts
3 bearing bolts for side chain guides
3 crankshaft pulley bolts
Valve cover (not really necessary, but while you're looking )
3 bolts for the water pump drive idler, this is the one that is between the crank and water pump pulley.
4 Top engine mount bracket bolts to engine
4 top engine mount bolts to top bracket
3 top engine mount isolator bolts
I think that will do it for now, any help is appreciated!!!
Pat
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
makg
Aug 21, 2015 02:49 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
