R56 N14 JCW OEM Airbox cone filter on N18 Engine
Old Aug 22, 2013 | 04:46 AM
StuRat's Avatar
StuRat
As far as the mounting screws not lining up when adding an N14 airbox upper housing to an N18 lower housing, has anyone replaced the bottom airbox housing (on an N18) with the N14 housing then added the "old" cone style gen2 JCW airbox.... I was told this works and has been done at WMW. I'm about the pull the plug on both a JCW intake (JCW AI PN: 13720429380) and the whole Intake muffler assembly housing (Intake Muffler PN: 13717577509) and see if it will fit on the N18 (Gen2 GP).... I have to get the whole stock N14 Air Intake to get the bottom housing part of the N14.... unless I find a used one
Any input or pictures would be great
This will be done on a Gen2 GP
Old Aug 24, 2013 | 01:04 PM
cesar418's Avatar
cesar418
I have a 2011, bought a JCW airbox with the cone filter and then sourced the bottom of an N14 airbox, fits with no problems at all, the sound is the same as with the stock box
Old Aug 24, 2013 | 07:31 PM
StuRat's Avatar
StuRat
Great, just the news I was looking for.
So you took the N14 OEM JCW air box (with the JCW Logo) , mounted it to an N14 stock bottom housing and it all bolted right up to your N18 brackets????
I'm not worried about the sound but I heard it will or should make a difference in the throttle response.
How did you find it as far as an improvement ???? Is it worth the change out????
Did you keep the paper cone filter od do the K&N or equivalent????
Old Aug 25, 2013 | 08:34 AM
cesar418's Avatar
cesar418
Yes that's what I did. To tell you the truth I did not find much, if any difference, before that I was running a cone filter(apexi) with the airbox bottom. I could feel gains on the top end, but a little heatsoak while starting to get the car moving. With the JCW box you get that lower power back, but you feel it lagging up top. I believe the biggest drawback of the JCW box is the paper filter, as when youre going full throttle it doesn't let enough air pass thru. I still have to change it to a cottom type filter to see what the differences will be.
Zettinger
Aug 25, 2015 04:04 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
flredmini
Aug 12, 2015 06:35 PM
SuperGreg
Aug 11, 2015 05:56 AM
