R50/53 '03 MINI Cooper Headlight replacement
Old Aug 9, 2013 | 07:29 AM
winniethemini07's Avatar
winniethemini07
I have an 03' MINI and the flimsy plastic casing that new headlight bulbs plug into is literally disintegrating. Result? One headlight shines straight forward, the other flops down. Not quite a pididdle, but definitely a lazy eye. I've done a little searching and it looks like my only option is replacing the entire headlamp assembly? Has anyone dealt with this problem before? Can anyone point me in the direction of a simple replacement part or any other suggestions?
Thanks!
Old Aug 9, 2013 | 06:43 PM
ryan4thewin's Avatar
ryan4thewin
my buddy showed me a plastic thing you twist and this adjusts the up/down direction of the headlight, if you pop your hood and look under at the light it looks like a plastic bolt and it should be labeled up/down on the plastic bolt
i dont think you need new headlights, although ive been eyeballing some LED's
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
