R50/53 Voltage Drop
Old Aug 7, 2013 | 10:10 AM
daflake's Avatar
daflake
Voltage Drop
Okay, I have been searching and can't really find anything on this one so I am reaching out. I have an 06 MCS where the voltage is dropping to 12.0v when the AC is turned on at idle. Once you tap the gas it jumps up to 13.5 volts and if you are moving it is fine. I thought it was the voltage regulator that might be going bad, so I put a new alternator in but that did not solve the problem (still needed to be swapped as the other had 99000 miles on it).
Any thoughts on why the AC is drawing so much current? Anyone seen this?
Old Aug 7, 2013 | 10:59 AM
ZippyNH's Avatar
ZippyNH
The only part of the ac that uses power is the blower fan....
So I'm guessing the idle might be dropping a bit when the a/c clutch engages.... Resulting in a voltage drop....so the regulator might be iffy...but have seen a couple cars do this with very high mile alternators.....(200,000 mile OEM ones...)...that still were working...
Just a heads up...one of the guys (at greasys) mentioned to me that the car-quest alternators seem to be lasting only about 2 years....so still not a good OEM equvelent...good for some...due to the $$ savings, but I can tell you the OEM denso's on other cars can go 200,000+ ....had had 3 do this...2 honda's and a Toyota Highlander currently (at 210,000+).
I have found denso made rebuilds from denso online for a decent $$....heck bet they are the OEM rebuilds they are selling....still 2x the cost of the rockauto ones.....
Old Aug 7, 2013 | 11:03 AM
ZippyNH's Avatar
ZippyNH
One extra thought....
About the blower...
Worn DC motors sometimes need a bigger surge current to get them moving....I would expect the fuse to blow if too far gone....check the grounds? Have also heard of a car or two that had corrosion issues on the back of the fuse block....
Old Aug 7, 2013 | 11:26 AM
Frozone's Avatar
Frozone
Did you try replacing the battery?
Old Aug 7, 2013 | 02:38 PM
daflake's Avatar
daflake
Hmm.... Blower motor should show a drop with or without AC on right? Also, the battery is fairly new (less than a year).
Interesting on the TYC as I have used them in the past and they lasted a lot longer than that. I guess I will find out.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
navybsn
Oct 4, 2015 03:27 PM
pglgp1292
GP Talk (2006)
Oct 2, 2015 10:34 AM
aldito2
Sep 30, 2015 10:44 AM
Samhillrocks
Sep 29, 2015 12:55 PM
