R50/53 Power Steering Pump Cooling Fan
I have had to replace a power steering pump because of a cooling fan failure already. As a result I keep a pretty close eye on that cooling fan to make sure that it is working. I usually turn on the air conditioning to start the fan (something that I learned from this forum). The thing is that my air conditioning has failed just recently. I don't mind the loss of the air conditioning for now but when I did a check on the power steeing pump cooling fan recently, it wasn't working. I am wondering if the loss of the air conditioning could somehow stop the pump cooling fan from kicking on.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Obviously coolant temp will do it, but the other thing is X # of Bars of Pressure in the cooling system. Not sure exactly what that means, but I assume it's the freon Gas being pressurized by the AC compressor.
My engine cooling fan is working so is it possible that ps fan is working but I just can't trick it into starting up by turning on the air conditioning? I guess that I can just let it run until the engine fan comes on and then check the ps fan.
My ps fan doesn't work, but the pump runs fine. I need to look at fixing mine before the pump fails.
I know with mine, the fan doesn't even turn freely by hand -it's gummed up with dirt I'm sure. My AC and cooling fan both work though. I was planning to remove mine, try to clean it up, and jumper it to 12V power before I buy a replacement ps-fan.
Edit; ps, sorry to hear about your AC. Hope you can stay cool inside the car.
Etrain
16
Aug 5, 2024 04:37 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
