Suspension adjustable camber plates for KW V2's
Yes I saw them but wasn't sure if that is a good brand.
Vorschlag is on of the best camber plates you can get for the MINI. They are well known in the racing community and make excellent products that have seen track time on Porsches, BMWs, MINIs, Evos, etc. If I were in the market for camber plates, they're my only brand I would consider.
As an alternative, maybe give TC Kline a ring and see what they have or recommend.
I would give them a call to be perfectly honest. They'd know exactly what to recommend for you.
http://www.waymotorworks.com/vorshla...er-plates.html
So I sent them a question thru their website, and he said for the stock KW V2 setup I should get the stock spring perch. Does anyone know what would happen if I used the wrong perch spring size?
Give Way Motor Works another call and leave a message if you can. When you do reach Way, let him know what you are trying to do and what suspension upgrades you have already.
For example... (pulled from Vorshlag's website and these are not OEM mini springs but gives you an idea)
If you notice the KW V2s use a spring similar to stock diameter on the top which is why you are needing the spring perch for "stock springs" even though you're using aftermarket springs. Here is a picture of the KW V2 setup for Minis.
Oh awesome!! Stock perch spring it is. Thanks alot v10climber!!
You'll know if you have the wrong perch size. Stock springs are a much larger inner/outer diameter than typical aftermarket coilover springs (like hypercoil or swift).
Vorshlags are the best camber plates you can get.
If you have the standard off the shelf KW V2s you need the stock size spring perches.
If you have our custom TSW spec KW V2s you will need 60mm perches as we use special linear springs matched for the MINI to improve performance.
