R50/53 Parts/gaskets/fluids needed for water pump install and SC service?
Old Aug 5, 2013 | 03:05 PM
youloze's Avatar
youloze
Hey all, I'm about to order everything I need for the SC oil service and water pump replacement. Can you take a look at this list and let me know if I'm missing anything important or something I should do while I'm in there?
-Water pump
-Water pump flange (do I need this?) http://www.ecstuning.com/Search/SiteSearch/11517509170/
-Water pump to block o ring (does this usually come with the pump or are there two?)
-Coolant
-SC oil
-SC inlet gasket
-Throttle body o ring
-Crankshaft position sensor o ring (because I'm in there)
-Low speed fan resistor (car must be in service mode for this right? May as well do it now)
-SC pulley, plugs, belt and tensioner stop (because I want to go fastar!)
Anything I'm missing?
Thanks!
Old Aug 5, 2013 | 03:09 PM
JoeGravelle's Avatar
JoeGravelle
Don't forget the SC outlet gasket
Distiller water to mix with the coolant
When doing the SC everyone removes the MFE( modular front end) to make the job easier
Old Aug 5, 2013 | 03:12 PM
youloze's Avatar
youloze
Yeah definitely taking the front off to get it into service mode. Thanks for the reminder on the outlet gasket!
BTW, I have a 2% crank pulley and I'll be going with the 15% SC pulley. Thought I read that I stick with the stock belt size, is that correct?
Old Aug 5, 2013 | 04:15 PM
ACallahan's Avatar
ACallahan
Got your belt tensioner release tool?
Old Aug 5, 2013 | 04:17 PM
youloze's Avatar
youloze
Yes sir, have that already. Also borrowing the pulley removal tool for the SC pulley.
Cereall
Sep 5, 2019 06:05 PM
KrisMiss
Jan 3, 2016 02:02 PM
kpl
Aug 11, 2015 04:52 AM
kwijmbo
Aug 5, 2015 09:00 PM
