Suspension Torque Specs for H-Sport Comp Rear Sway Bar Bushing Brackets?
Old Aug 3, 2013 | 11:46 PM
Systemlord's Avatar
Systemlord
I'm going to be installing my H-Sport 25.5mm Comp Rear Sway Bar tomorrow and the instructions that came with have no torque specs at all, not even on the Hotchkis Sport Suspension website. I have all the other torque specs for everything else, sub-frame bolts, top shock mounts, lower shock mounts, end links and lug bolts. I need the specs for the torque specs on the Hotchkis bracket bushings please!
Thanks in advanced!
Systemlord.
Old Dec 7, 2013 | 07:29 PM
afadeev's Avatar
afadeev
Thanks in advanced!
Systemlord.
I just did my rear sway bar the other month.
Assuming you are using stock M8 bolts to attach sway bar bracket to the rear sub-frame, torque them to 14 ft-lbs (19 Nm).
a
Old Dec 8, 2013 | 09:11 AM
countryboyshane's Avatar
countryboyshane
It's not much. Lots of bad stories about people stripping them out from having a gorilla arm. Just snug it down and mark the bolts with paint so you can see if they are vibrating loose.
W0TM8
Dec 19, 2019 07:50 AM
Bennyboy
Aug 18, 2015 07:28 AM
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
