Have an '07 MCS with 195/55/16 " summer tires. (Stock). Was given a set of 4 winter tires not mounted. Size 205/55/16 off a Mercedes. Question is will these winter tires fit on my stock rims? Thanks in advance for any help.
I have a set of stock OE 16" wheels with Pirelli Sotto Zero 2 winter tires on them that are that same size, 205/55/16. (I bought the 205/55/16 because that size was nearly $100 cheaper than the 205/50/16 for some reason.) The tires fit fine except when the steering wheel is turned full lock they rub very slightly on the inner fender liner. I have only ever experienced this in parking manuvers.
So yes, use the free tires you were given. They will be fine.
