17x8 ET35 wheels?
Using stock suspension it should fit.
Compared to stock 17x7" wheels, the 17x8" et35 will stick out by 13mm or 0.5" which is fine.
205/40-17 fits rims 7-8" wide, but it is not OEM sized and runs small on tire diameter at 23.5". Used with stock suspension will give a larger wheel gap.
If you roads are smooth and good then the 40 series sidewall will be OK but if you have potholes watch out.
A better choice for tire size is 205/45-17.
Yep
lol this is on my current wheels right now. I am lowered on some sort of springs. I bought the car and the previous owner had lowered it. I have no idea what the spec of the wheel is. I have yet to pull a wheel off to check to see if the offset is stamped on the inside of the wheel.
I am looking at a set of rota torques that are the listed specs so we will see how they look. I am currently cambered in slightly on all wheels I may have to adjust the camber a little more when i get these guys mounted. Does the car have stock adjustable camber plates/arms? I spent about 30 min looking around online trying to find how to adjust them if so with no luck.
SosoMINI
Nov 22, 2015 03:17 PM
