R56 Fault Codes and Throttle Body
Old Jul 25, 2013 | 01:08 PM
wakxed's Avatar
wakxed
First time poster, been stalking for the answer to this but to no avail.
I have a 2009 MCS 100% stock. I am just about to hit 50k miles and yesterday I got the yellow check engine light. Had AutoZone run the codes for me and it spit out P0120 and P0221. Both are related to the TPS (throttle position sensor) . I don't live near a dealer so that isn't an option at this point. The car seems to be running normally except for the code so I wanted to check my throttle body to see if there has been any wire corrosion/rubbing or if the body is just getting caked with grime.
Question 1: Where the hell is the throttle body on the N14 engine? I'm looking all over the place and I can't find it.
Question 2: How do I clear the check engine light, assuming I am able to solve the problem?
Question 3: Is this a common issue? Has anyone else successfully fixed this?
Thanks in advance
Old Jul 25, 2013 | 02:43 PM
MiniPitCrew's Avatar
MiniPitCrew
If you're getting throttle position sensor error codes, shouldn't you be looking into the throttle position sensor, i.e. the sensor that is attached to the accelerator pedal? Why are you looking into the throttle body?
Old Jul 25, 2013 | 04:02 PM
Slave to Felines's Avatar
Slave to Felines
Because on cars that do not have electronically-controlled throttles ("drive-by-wire"), the sensor is on the throttle body itself and not on the pedal.
Old Jul 25, 2013 | 04:18 PM
MiniPitCrew
Ah, that would explain it! You learn something every day.
Old Jul 25, 2013 | 05:00 PM
nrfitchett4's Avatar
nrfitchett4
when I was researching spraying seafoam into the engine to clear some carbon, I saw some videos on youtube where people spray it right into the throttle body.
Took some digging to realize our car's throttle body is very hard to get to on the bottom of the engine and not worth it...
Old Jul 26, 2013 | 06:50 PM
wakxed's Avatar
wakxed
That is quite unfortunate. Guess I'll be taking the turd to a random mechanic to take a look. This should be a good time.
Sep 1, 2022 09:50 AM
mdutton11
14
Oct 26, 2015 01:47 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Moddedmafia
Sep 1, 2015 09:52 AM
reg66
Aug 31, 2015 02:41 PM
