R56 Most performance gain $300-500
Old Jul 24, 2013 | 11:46 AM
2010CHILI's Avatar
2010CHILI
I have a 2010 MCS auto and am considering entering the slippery slope of performance mods. Right now my S is bone stock aside from a K&N drop in.
What performance mods will do the most for me between $300-500?
Thanks!
Drew
Old Jul 24, 2013 | 11:49 AM
Braminator's Avatar
Braminator
Start with the handling aspect like a rear sway bar. You will be amazed after it is on.
Old Jul 24, 2013 | 12:09 PM
countryboyshane's Avatar
countryboyshane
You want a big leap in horsepower? Expect to may at least $2000 for everything that's needed. Doesn't make sense does it
The Helix short shift kit and H-sport competition rear sway bar are the best things you can do to the MINI for under $300.
Old Jul 24, 2013 | 02:22 PM
cmt52663's Avatar
cmt52663
Truly, truly! And you can take this mod with you to any vehicle!
Cheers,
Charlie
Old Jul 24, 2013 | 02:46 PM
Capt_bj's Avatar
Capt_bj
find a good go-kart track that teaches driving ..... or what he just said . . .
you'll improve your times WAY more than any bolt on.
Old Jul 24, 2013 | 07:37 PM
bmwr606's Avatar
bmwr606
driving school!
Old Jul 24, 2013 | 07:49 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
For $300-500 I would go with an Hsport Comp Sway bar
but for real engine performance I would go with a Forge Intercooler
Old Jul 25, 2013 | 09:14 AM
mbwicz's Avatar
mbwicz
The NM lower engine mount makes a signficant difference in reducing torque steer, for $60 it is worth a try. There is also the 'free camber mod' in the front, which along with an alignment is a good thing.
There are no quick/cheap mods to get more HP, so focus on handling and driver training.
Have fun,
Mike
Old Jul 26, 2013 | 05:21 PM
KilmerPT's Avatar
KilmerPT
For $10, I think the BMS clutch stop is worth it, if you drive a manual, for quicker shifting.
Old Jul 26, 2013 | 05:53 PM
2010CHILI's Avatar
2010CHILI
All great suggestions so far! I do believe I will be focusing on handling mods to start with. Front and rear sway bars and a STD/SARS set up maybe? A little over my initial budget, I know, but doing them one at a time might not hurt too bad :-)
All this is in prep for classes and racing AutoX next spring, so I have that covered.
MCS2011, I went with an automatic so that one is no good for me, but I have heard that's a good cheap manual mod.
Drew
Old Jul 27, 2013 | 04:07 PM
mbwicz's Avatar
mbwicz
Most people don't change the front sway bar for a couple of reasons: 1. It is a monster job (I've read from 4-8 hours to do the job). 2. The mini benefits from a stiffer rear bar, in conjunction with the stock front bar. If the front bar is made stiffer, you may need even more stiffness in the rear to balance the car.
Keep reading here, there are several good discussions in the Mods:suspension section. Just scroll down the topics from the past and you will likely get some good info.
I also recommend that you keep an eye on the used parts in both marketplaces. Sometimes there may be something that fits your needs for cheap.
Also notice that nobody recommended lowering springs or shocks in your budget.
Have fun,
Mike
xpunisherx
Nov 27, 2015 03:32 PM
Sep 2, 2015 12:55 PM
Sep 2, 2015 11:15 AM
Sep 1, 2015 04:39 PM
Aug 21, 2015 11:25 AM
