R50/53 JCW Strut Bar Question
Old Jul 13, 2013 | 10:00 PM
rennwerkes's Avatar
rennwerkes
Hope this isn't a stupid question.
But was wondering if I needed washers to bolt down my strut bar on my 06 S.
The reason I ask this is that the bolts don't come all the way through the nuts.
And if I do need to use the washers where should they go? Under the bracket or on top? As they are now, they're under the bracket.
Thanks!
Old Jul 14, 2013 | 12:03 PM
mrbean's Avatar
mrbean
If you're using the old nuts which are flanged, then no washers are needed. If you're using nuts that aren't flanged then the washers should go between the nut and the bracket.
Old Jul 14, 2013 | 12:38 PM
<05MINI>'s Avatar
<05MINI>
Originally Posted by mrbean
if you're using the old nuts which are flanged, then no washers are needed. If you're using nuts that aren't flanged then the washers should go between the nut and the bracket.
+1
Old Jul 14, 2013 | 01:26 PM
rennwerkes's Avatar
rennwerkes
Thanks!
That's what I thought too but was wondering if the PO knew something I didn't! LOL!
Dec 23, 2015 10:36 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
