Brake pad warning light.
Old Jul 10, 2013 | 06:08 PM
PFCflanders's Avatar
PFCflanders
So today as I got home the brake pad warning light flashed on briefly. In the manual it says that it means i should check the condition of my pads. I have the stock pads and rotors with 39k on them. Should i replace the pads now? Should i have replaced them already? Should i replace both? Assistance pleeze.
Old Jul 10, 2013 | 06:29 PM
donjulio's Avatar
donjulio
The pad lights come on when there is about ~3/10 of the thickness left on the pads. So you don't really have to worry about it for a while...
Old Jul 10, 2013 | 06:33 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Yes, check the thickness of the pads, both front and rear...but, in all probability, the fronts wear faster than the rears. You can use an inspection mirror and a flashlight to see both the inner and outer pads of each caliper. I seriously doubt you'll need new rotors unless they're seriously scored. Don't wait too long to replace the pads. If you do, you'll run the risk of getting down to the pad backing plates which will score the rotors so deeply, you'll probably have to replace them.
Old Jul 10, 2013 | 09:33 PM
PFCflanders
Thanks, I was planing on putting some EBC Redstuff pads anyway in about a month.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Tires, Wheels & Brakes
Aug 26, 2015 10:28 AM
Aug 25, 2015 09:18 AM
