R50/53 where do I tap in for boost gauge?
Old Jul 10, 2013 | 03:58 PM
DTMR's Avatar
DTMR
I just got a prosport gauge and alta pod. I tapped it into this line on the passenger side of the intercooler and when I floor it the gauge just goes to zero. Also the vacuum line runs across my entire engine bay (not pretty) does anyone know the right place to tap into for it? Why its not working?
Old Jul 10, 2013 | 06:55 PM
tweiss8's Avatar
tweiss8
I have the same problem, I believe I have used the same vacuum only line that you have. I believe that the proper line to tap into is under the intercooler. I think that there is a nice write up in the "how to" section of the forum.
Old Jul 10, 2013 | 08:08 PM
DTMR's Avatar
DTMR
Yeah I found it, it was on the manifold itself but a little PITA to get to. I seem to be pushing only like 13 psi is that normal for a mini with a 15% pullet and intake?
Old Jul 10, 2013 | 08:16 PM
tweiss8's Avatar
tweiss8
I would tell you that it could be, how many miles on the car? It could be age wearing on the engine/supercharger
Also could be a bypass valve that's not shutting all the way. I'm told that when everything is in order it should be about 15lbs. Again that's not to say there is something wrong with your car at all.
Old Jul 10, 2013 | 08:17 PM
tweiss8's Avatar
tweiss8
Snap a picture if you can of the line that you used to have it read boost. Very curious.
Old Jul 10, 2013 | 11:19 PM
DTMR's Avatar
DTMR
I used the line on the manifold under the intercooler I will try to snap a pic for you tomorrow
Old Jul 10, 2013 | 11:20 PM
DTMR's Avatar
DTMR
I just changed the fluid on the supercharger and it still had fluid in it :/ car is an 03 with 112,000 miles just put the pulley on I need to check more though.
Old Jul 11, 2013 | 01:47 AM
BlwnAway's Avatar
BlwnAway
The Intake line is the one most of us use, it runs from the manifold to the fuel regulator, so be Absolutely Certain that all of the conections are tight, a vacuum leak on that line can cause a lean-out condition under WOT.
Old Jul 11, 2013 | 01:26 PM
DTMR's Avatar
DTMR
i think I actually am hitting 15 psi but more towards redline lol guess i wasnt hitting it hard enough? but Its weird maybe cuz my engine was hot I dont know I need to find out!!!
Filmy
15
Jun 6, 2023 06:27 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
schwac2
Oct 17, 2015 06:03 AM
molala
Oct 2, 2015 01:53 PM
gzaos
Sep 14, 2015 04:21 AM
