will these fit on a 04 r53
http://www.dubraderwerks.com/product...1-replica.aspx
Will these fit with just some nm lowering Springs without any rubbing or issues?
Are those the actual rims you are interested in?
DUB 0.01 3 piece Mesh, Hyper silver with machined lip
$599 each
17x7.5" et35 4x100
Compared to OEM 17x7" wheels, these will stick out 13mm or 0.5" farther.
With a lowered suspension, how much clearance do you have right now with your current (205/45-17?) tires. Is there room for a tire that sits 0.5" out wider or is it already really close?
If there is some clearance then you can use tires sized-
205/40-17
205/45-17
215/40-17
235/40-17 (this has the least clearance)
Or you can stretch a narrow tire on the 7.5" rim.
You won't be able to use a tire size taller than OEM due to rubbing.
$599 each
17x7.5" et35 4x100
205/40-17
205/45-17
215/40-17
Aug 12, 2015 01:24 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
