Electrical R53 headlights pointed down
Old Jul 2, 2013 | 07:30 PM
Mikestrat's Avatar
Mikestrat
After the car sat unused for 2 weeks, the headlights do not move from down position. When I turn on the lights I can hear a motor sound. What part of the headlight-leveling system has gone wrong?
Old Jul 15, 2013 | 09:19 AM
heresmymind's Avatar
heresmymind
there are 2 possible things you can do to fix this.
1) manually adjust them when they are on with a flat head screw driver, there are 2 plastic screws behind the headlight, 1 for up and down and 1 for left and right.
2) the sensor is located on the driverside control arm, make sure the plug is still in and that the bracket is not bent, mine got bent accidently when I did my Control arm bushings that I had to replace.
If you manually adjust them and they still dont adjust, i recommend unplugging the control sensor on the control arm, and just adjusting them again so they stay where they should be. The auto levelers on our cars suck in comparison to others. I plan on altering it to a manual switch to level them in the cab
-B
Old Jul 15, 2013 | 12:38 PM
Mikestrat's Avatar
Mikestrat
Thanks for the reply.
The headlights are way too far down for the fine adjustment screws to make a difference. The sensor looks good, but I might just replace it to see if that works.
Otherwise, I may try to shim or ziptie the headlights up into a straight position.
Old Nov 9, 2013 | 11:11 AM
RUDEBOX's Avatar
RUDEBOX
My 1st gen R52 HID has done this. It popped out of its mount points inside it seems. Not sure I want to take it apart to fix this. If I do, I am guessing I will follow the Joey Mod directions for taking apart the headlight. Anyone have this happen to theirs and fixed it? Or has everyone just replaced the whole unit?
silence2-38554
98
Sep 21, 2016 02:52 PM
R53Mom
Aug 17, 2015 01:38 PM
pewx3
Aug 7, 2015 03:34 PM
