R50/53 who can tell me about this part number
That's a tough one. If you look at the diagram of clutch on realoem you'll see it in the diagram, but no part number, and I'd be surprised if it comes with the clutch line that runs through it.,,, but I'd almost like to see a photo of that clutch line as it comes out of the box. The diagram looks like it "could be" a part of it.
I'm curious now. Let us know what you find as you track down this grommet.
Its part of the clutch line going into the firewall right behind the brake servo. Not a separate part via the diagram, it you can see if there is a 7 digit or 13 digit part number molded into the rubber that might shed some light. Its not in the grommet diagram either , that shows all the plugs and grommets.
Part number 11 for the "Cooper S" R53 R52 models. Cooper has ia diffrent part number but is the line with the grommet.
http://www.ecstuning.com/Search/SiteSearch/21526774286/
ryGuyMCS
Oct 20, 2015 02:24 PM
Drivetrain Replacement MAF Sensor Plug Clip
absolutcamper
Aug 24, 2015 12:27 PM
nomar116
Aug 21, 2015 04:36 PM
