R50/53 when should you upgrade the intercooler?
Jun 24, 2013 | 04:49 PM
I just ordered my alta intake and I have a 15% pulley on my R53 I plan on doing an exhaust and upgrading the ignition and than tuning it, but when is it necessary to upgrade an intercooler?
Jun 24, 2013 | 05:00 PM
There's never a bad time to upgrade it really. The GP intercooler is the best alternative, unless you want to spend more on the DoS or something else.
Jun 24, 2013 | 05:06 PM
Quote:
Originally Posted by
Da_Ghost
Where can I get the GP intercooler?
Jun 24, 2013 | 05:13 PM
Only the gp is proven to be better...others are compromises...
In all honesty...the sc is not a big power gain in a gen1....$$ per HP...it is at the bottom of the list.
Jun 24, 2013 | 05:33 PM
DTMR
Most sellers like Outmotoring, WMW, etc, usually have them listed.
Jun 25, 2013 | 12:58 PM
Yes you def want to go with the
GP intercooler, fits perfect and works great too. We found it more efficient than most aftermarket ones.
Jun 25, 2013 | 09:01 PM
I have a GP intercooler and noticed heat soak isnt as bad at idle and cools off rather quickly. Seems highly efficient too, no pressure drop at all.
Jun 26, 2013 | 07:06 PM
This is probably a dumb question but do you use the stock boots with the gp intercooler or no.
Jun 26, 2013 | 08:04 PM
I used the stock boots on mine. The horns on it are exactly like the stock one. If you look at it off the car it literally looks like they cut and added a couple of extra rows at the top. I got mine for when it is really hot out to get rid of heat soak easier when moving. Worked as advertised.
Jun 26, 2013 | 08:09 PM
<05MINI>
I used the stock couplers but I have ALTA couplers. Not putting them on til I know the IC is stayin on for a while.
Jun 27, 2013 | 03:32 AM
Jun 27, 2013 | 05:45 AM
Be sure to get the go diverter to go with the ic.... Or those extra cooling rows in the ic will not be expo's d to the cooling air....
Jun 27, 2013 | 04:22 PM
Alta couplers are a ***** to install tho. Unless your boots are old and start to crack, I would keep the oem ones.
molala
Oct 2, 2015 01:53 PM
OutMotoring
Sep 8, 2015 06:27 AM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
