Exhaust smell in cabin
Old Jun 24, 2013 | 04:32 PM
QuickCooper's Avatar
QuickCooper
Hi guys and gals, I seem to be having an issue with my bone stock 06 MCS. When I get on the throttle hard, or even part throttle I can smell the exhaust inside the car. It still smells with the a/c on recirculate. When driving normal I don't smell it. The car runs perfect otherwise.
Has anyone else had this problem?
Old Jun 25, 2013 | 02:01 PM
You might have a exhaust leak up near the exhaust header in the engine bay. Check for gasket leaks. The other place that might have a leak but is usually when sitting still is near number 4 in the diagram. If its not the gaskets then it could be the pipe.
Exhaust Manifold Gasket #2 part number 11621174968 make sure all the bolts are there an torqued down.
http://www.ecstuning.com/Search/SiteSearch/11621174968/
http://www.ecstuning.com/Search/SiteSearch/07136800269/ Bolt x 8 needed.
For the rear , its moslty when setting still.
Hex nut with flange. x 2 #5 in diagram.
http://www.ecstuning.com/Search/07130757758/ES16372/
Here is the threaded Bolt x 2
http://www.ecstuning.com/Search/18107520438/ES39444/
Number 4 in diagram . Check for leaks at this gasket connection.
http://www.ecstuning.com/Search/18111170941/ES39515/
Thanks and hope that helps. If you can have someone throttle the engine while parked and check for noise of a leak and location, that will help pinpoint it.
Old Jun 28, 2013 | 08:55 AM
QuickCooper
Thank you for your input
Old Jun 28, 2013 | 12:55 PM
You are welcome.
patsum
26
May 29, 2021 06:29 PM
embiggenedmini
Oct 15, 2015 12:36 PM
molala
Oct 2, 2015 01:53 PM
buckeye_hunter
Sep 2, 2015 01:24 PM
Sep 2, 2015 09:05 AM
