R50/53 OEM gauge swap (chrono)
Old Jun 24, 2013 | 04:30 PM
ti22fjc's Avatar
ti22fjc
Hi!
My wife and I each have MCS. Mine has the dual pods and the chrono gauges in the center. Her's is the tach on the steering column and speedo in center.
If I were to get the dual pods and the chrono gauges for the center, would this be a simple plug and play type of install or would I be looking more into it? And if so, what? extra wiring, tapping wires, etc?
Thanks,
Noel
Old Jun 24, 2013 | 05:13 PM
Deluded's Avatar
Deluded
It's not a simple swap. The center speedo won't work in the car with chrono and the dash speedo won't work in the normal cooper.
It's the wires. Unless you feel adventurous and like basically gutting your car (including a reprogramming or two) to make the normal speedo work in your chrono car ... Not worth it.
There's a thread somewhere on this site where people have done the same exact thing.
Furthermore, the swapped gauges will not report the correct mileage too.
Old Jun 24, 2013 | 05:18 PM
ZippyNH's Avatar
ZippyNH
Coding is required...and the miles on the odometer is stored....so you will have issues. The parts have the vins stored....NOT AN EASY SWAP...many have tried it...most have gone back.
Old Jun 24, 2013 | 05:42 PM
ti22fjc's Avatar
ti22fjc
Yikes!
I haven't purchased any parts, and with my (limited) MINI experience, figured it "wouldn't be easy".
Did the second gens have a dual pod?
Old Jun 24, 2013 | 06:02 PM
ASKtheteach's Avatar
ASKtheteach
Definitely not easy or cheap to do at all. And no, the Chrono Pack is not available on the 2nd gen cars. It was available in '05-'06 on the hardtops and '05-'08 on the convertibles.
Old Jun 24, 2013 | 06:11 PM
ASKtheteach
Branto
Aug 11, 2017 05:32 PM
blackie
Oct 2, 2015 07:41 PM
missinmyjeep
Aug 22, 2015 07:13 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
FLYM1N1
Aug 16, 2015 01:15 PM
