Drivetrain jcw map sensor vs r56 s sensor
Old Jun 23, 2013 | 06:19 AM
SPRINTCARS's Avatar
SPRINTCARS
Whats the difference between the r56 "s" map sensor and the jcw sensor ? i seen another thread about using the jcw sensor but nobody elaborated what or how it effects the car by changing it. i have a tune on the car and come to find out its a generic/ same a jcw tune with the boost turned up alittle more. then i seen the post about using a jcw map sensor in the r56 car. what is the difference with the sensors ?
Old Jun 23, 2013 | 08:40 AM
SPRINTCARS's Avatar
SPRINTCARS
does anyone have any input about this ?
Old Nov 13, 2013 | 07:50 PM
gsxrdustin's Avatar
gsxrdustin
The JCW one will allow the car to be turned up to higher boost pressures. The factory sensor does not allow for the boost to. be turned up past a certain point. If it see higher than allowed boost pressures it will boost cut. There are not direct performance increases by installing the sensor but it will all for higer boost pressures meaning more power
silence2-38554
98
Sep 21, 2016 02:52 PM
Dec 23, 2015 10:36 AM
mdutton11
14
Oct 26, 2015 01:47 PM
