Suspension NM's new 22mm rear sway bar w/zerks
Old Jun 20, 2013 | 10:24 AM
SuperGreg's Avatar
SuperGreg
First off, I already tried searching topic and no luck.
I'm a fan of nm products, and their 22mm rear sway bar for the R56 now comes with zerk grease fittings on their custom CNC machined brackets. I also like their graphite impregnated urethane bushings.
NM's new 22mm rear sway bar w/zerks-image-1030297176.jpg
Link to bar:
http://www.nm-eng.com/290/0/0/1462/n...products%5D/0/
Has anyone here installed yet? Thoughts?
Well debated topic, but should I stay with stock end links or replace with something like WMW's sealed ball adjustable ones?
http://www.waymotorworks.com/wmw-adj...-endlinks.html
Thanks in advance!!!
Old Jun 20, 2013 | 05:16 PM
mbwicz's Avatar
mbwicz
I have read that the factory end links are fine, especially on the rear. On very low cars, the factory front endlinks can interfere, but I have heard that the factory ones are ok on the rear. If you are corner balancing your car, or really serious about setup, then adjustable ones will allow you to avoid preload on your sway bar.
That being said, I picked up a used set of aftermarket ones on the marketplace, and have not had any issues. If I was going to buy a set new, I like the ones from WMW.
Mike
Old Jun 20, 2013 | 05:18 PM
SuperGreg's Avatar
SuperGreg
Thank you for your thoughts!
Old Jun 20, 2013 | 05:49 PM
jkapinos's Avatar
jkapinos
22mm NM sway bar
They have been out for a while. I purchased mine a few months ago. Installed it two weeks ago and I'm very happy with it so far.
Old Jun 20, 2013 | 06:48 PM
SuperGreg's Avatar
SuperGreg
Sweeeet, that looks awesome!! I see you have it set in the middle. Any oversteer?
Old Jun 20, 2013 | 07:00 PM
jkapinos's Avatar
jkapinos
No, what I installed was, 22mm sway bar, rear NM end links, front Way end links and NM RSa springs. The car handles very well. I'm taking turns about 10 MPH more then before and the car is very stable and wants more.
Old Jun 20, 2013 | 07:29 PM
SuperGreg's Avatar
SuperGreg
Just ordered my nm bar through my authorized nm MINI dealer for $209 (MSRP is $299). Great deal IMO.
Old Jun 20, 2013 | 08:18 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Factory endlinks are fine, unless you're lowering the car and need some adjustment. When you re-install the nut to attach the endlinks to the RSB, use some threadlocker. Otherwise you'll end up taking your wheels off in a month or so to tighten them up to get rid of the god awful rattle that develops when they loosen up. (I speak from experience... )The nuts have a little "castle" on the top that I'm guessing provides the locking function when they are installed new, but it doesn't seem to work after the nuts have been removed and re=installed.
Old Jun 20, 2013 | 08:33 PM
SuperGreg's Avatar
SuperGreg
Thanks for the tip!
Old Jun 22, 2013 | 02:08 PM
SuperGreg's Avatar
SuperGreg
Ok, so I ordered it. Got it for $209!!! Should be in Monday. Got quote for $135 labor to install at a MINI shop.
Old Jun 23, 2013 | 06:18 PM
07_JCW_MINI's Avatar
07_JCW_MINI
Where are you guys getting them for $209?
Old Jun 23, 2013 | 06:26 PM
SuperGreg's Avatar
SuperGreg
Don't know about anyone else, but getting mine from MINI of Tempe in AZ. Keep in mind that I bought my car there too, so he may be giving me a special deal. Sounds too good to be true. I'll know when I go to pick it up on Mon or Tue.
Old Jun 23, 2013 | 07:24 PM
Mindspin311's Avatar
Mindspin311
Seems a bit overkill, dont you think? Esp. for the price.
Old Jun 23, 2013 | 07:28 PM
SuperGreg's Avatar
SuperGreg
Huh? MSRP is $299. Cheaper bars are $199.
Old Jun 23, 2013 | 07:36 PM
SuperGreg's Avatar
SuperGreg
What's overkill?
Old Jun 24, 2013 | 06:28 AM
Mindspin311
Right, so you're paying $100 for some fancy brackets; when most aftermarket brackets, even without zerk fittings, get the job done just as well.
Old Jun 24, 2013 | 06:51 AM
SuperGreg's Avatar
SuperGreg
I'm not, that's why it's such a good deal at $209. Most other bars are still like $189-$199. Btw, the other brackets don't get the job done just as well when they start squeaking. If you don't like this setup, what would you recommend for a better value with similar performance? There's still time as I have not paid for this bar yet.
Old Jun 25, 2013 | 09:57 AM
SuperGreg's Avatar
SuperGreg
Bar is on and I love the feel!!
FYI, I had the factory bar measured and it is 18mm. That's with the sport suspension.
NM's new 22mm rear sway bar w/zerks-image-2352150825.jpg
Old Jul 1, 2013 | 08:16 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Don't know where you got that other brackets don't get the job done?? Been using Hsport Bars with flat brackets for years with no issues.
The problems that come up with sway bars is usually the bushings. The NM Bar, TSW, and Hsport bars come with bushings that actually work and hold the grease in them. Other bars have bushing where the grease just comes out and that causes the noises. The Brackets on the NM bar also nice idea, but make it much harder to install as you can't just put a wrench on the bolts.
Also the Hsport Comp bar weights only 5.5lbs beating everything else in weight savings.
Old Jul 1, 2013 | 08:28 PM
SuperGreg's Avatar
SuperGreg
My comment was "knee jerk" to a very shall we say "smarty pants " reply earlier from another poster. I was talking in generalities, suggesting that a bar with zerks has a benefit to the owner. I agree about the bushings and just learned about them during the install. The nm bushings had slightly recessed lines or channels to hold the grease. Also learned that not all bars with zerks have bushings with holes to accept the grease like the nm. I guess some have solid bushings which render the zerks worthless.
Old Jul 2, 2013 | 11:59 AM
WayMotorWorks
Vendor
You are correct. Your post may have been a smarty pants reply, but the issue is many readers of the forum don't realize that and then take it as fact. Or as I like to call it "Internet Fact" so I wanted to post a clear statement for future readers.
Old Jul 2, 2013 | 12:23 PM
SuperGreg's Avatar
SuperGreg
I didn't say my post was the smarty pants reply
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
