FS:: Velocity Adjustable Throttle Booster System
Price: $210
Location (Region): SouthEast
The Velocity Throttle Booster can be turned on and off to switch between the factory throttle setting and 4 selectable throttle presets. Each of the four throttle presets increases the responsiveness of the throttle from "mild @ 1" to "WOW @ 4," all are a noticeable difference. It gets scary fast! But also gets back to normal depending on what you want.
Using proprietary vehicle data monitors, the Velocity Throttle Booster (VTB) analyzes information and varies the opening angle of the throttle according to the throttle strength selected. Internal memory stores the driver's last selections so that the vehicle turns on in the same setting as when it was shut down.
Features:
- 4 power profiles selection (min, medium 1, medium 2, maximum 4), adjustable by the touch of a button on the control panel (+ or - )
- Unique “On/Off” button allows users to switch off the unit if they want to drive the car in factory mode
- Built-in memory function that retains last preset setting upon powering on
- Immediate throttle response to the engine in real-time, resulting in faster throttle response.
- Simple “plug-and-play” using MINI OEM Connectors, with no other modifications required
- Slim and Compact design
- Easy to completely remove from vehicle if necessary
Works great with my manual ’09 MCS. Had my car tuned and the VTB conflicted with my adjusted maps. If you are stock, and are looking for instant “pop”…you won’t regret this purchase. Paid $395…looking for $210…Cheaper than Sprint Booster and with extra setting. I’ll pay shipping in lower 48.
Ambient Thermal Management
Aug 7, 2015 12:27 PM
