2007 Mini Cooper S John Cooper Works no start
Old Jun 9, 2013 | 07:11 PM
yellowtib's Avatar
yellowtib
Hi
My Mini Cooper S R56 started the timing chain rattle noise. I bought a timing chain kit, and a cam timing tool kit from PROMINI to fix the problem. I unplugged the battery before the install, locked down the cams and the flywheel. Replaced all of the parts, and check the timing, everything was spot on. I put the car back together, tried starting the motor, the gauges turn on, and the motor turns over but doesn’t fire. I suspect no spark or fuel being delivered to the motor. I check all fuses and everything looks good. The car has a security system, which I suspect is the culprit. Any info on the cause of the problem and fix would be appreciated.
yellowtib
Old Jun 10, 2013 | 05:18 PM
boOst spIKe's Avatar
boOst spIKe
are you receiving a good cps signal? faults/cel present after performing attempted crank no start?
Old Jun 10, 2013 | 08:08 PM
yellowtib's Avatar
yellowtib
Boost spike
Can you explain more in detail how to check the cps signal?
bigramdizzle
Aug 6, 2019 09:19 PM
Dec 23, 2015 10:36 AM
joelcseymour
Aug 7, 2015 12:43 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
