Engine screech at 3k up rpms
Old Jun 7, 2013 | 11:22 AM
Muguerza's Avatar
Muguerza
So i started noticing my car would screetch at high rpms, im having trouble finding it, its kindof like a screetch grind noise, it is definately in the pulley and supercharger area, could be an idler pulley bearing or the belt slipping im not sure
I just had my tensioner damper replaced with an alta adjustable tensioner, and i have a new belt with the proper size for a 17% pulley and a 2% crank pulley
Has anybody ever had this problem, or does anybody know or have an idea of what it could be?
Old Jun 7, 2013 | 11:37 AM
ZippyNH's Avatar
ZippyNH
what size belt?
Look at the tensioner...how many holes do you see?
a -17% and a +2% is kinda unusual...give you about a 19% reduction
Old Jun 7, 2013 | 12:01 PM
Muguerza's Avatar
Muguerza
I have about one hole on the tensioner showing, both are alta pulleys, although the supercharger pulley is the v1. I have a napa 060539 belt on it, and i just installed it less than a week ago
I took out the tensioner itself to inspect the bearing but it is perfectly fine
Old Jun 7, 2013 | 01:16 PM
ZippyNH's Avatar
ZippyNH
The higher rpm screatch is USUALLY a sign of belt slipping....
in the past, alta's charts have been on the longish side for belts. I am honestly not sure which one for your combo...but with ONE hole showing, it should be ok...could be a bit tighter with a new belt..they do stretch...
V1 imo is a better pullet than their V2..so no issues there....edges of the belt look ok?
Old Jun 8, 2013 | 04:37 AM
Muguerza's Avatar
Muguerza
The edges sound okay, and i did hear some slip every now and then, i might have to go tighter on the belt
rob&JCW
Feb 13, 2023 07:03 PM
David.R53
Sep 1, 2015 06:49 PM
makg
Aug 21, 2015 02:49 AM
DWooderson
Aug 20, 2015 04:31 AM
stellaherself
Aug 14, 2015 05:28 AM
