R50/53 Stutter/Stumble in all gears under heavy-full throttle?
I am experiencing a "stutter" when applying heavy throttle in all gears; when rolling into the throttle moderately, I don't experience much of the stutter/stumble. I recently bought the car and did not have issues for the first week or so of driving it. I replaced the belt with a Gates K060535 belt last night and plan on replacing the plugs today to see if that solves anything (however when I pulled them yesterday, they didn't look bad).
I am new to MINI's, but not to modified automotive. If this were my Subaru, I would say the stutter felt like a result of timing, but since everything was fine a few weeks ago, it is a new issue and the ECU has not been touched. I did reset the ECU to see if that would help, which it unfortunately did not.
2004 MCS. Current modifications are only an Alta 19% pulley and Alta CAI. Mileage is 91k. No CEL or EML on. Idle is not erratic and boost is steady- I am stumped.
Any advice or possible explanations/ideas/theories on what is going on here or how to solve the issue (if it sounds similar to what you were experiencing) is highly appreciated!
Thank you to any and all in advance!
My suggestion....start by changing the 19% to a 17% or even a 15%.....very few cars that had 19% pullies installed kept them.....many issues.....like this.
Driven in town at lower rpms, a 19% is OK...but pushed hard...bad things start to happen.
Mileage is 91k.
Please let me know how it turns out with the new plugs and wires.
That is EXACTLY what I have going on. Please tell me that the plugs and wires fixes your issues...
Really? This is a proven thing? I do have an oil leak below that I am trying to track down. I have been checking the level everyday and all is good...weird.
Check the connectors on the coil pack especially for #3 cylinder as Way mentioned. Stock CP's are notorious for this issue reason why my stock one sits on a shelf and the NGK one is in the MINI.
You can clean it up with the green scrounge side of a sponge, nothing harsher than that though. Some say to put dielectric grease on those connections but that goes against what I have read regarding the use of that product. ( only to be used at the plug end of the wires )
Well today while I was on the on ramp for the highway, the car spit out a p0302 code for a cylinder #2 misfire. The plugs I initially ordered just came in so I put them in, but I am trying to find a way to reset the CEL and take It for a ride. An ECU reset doesn't get rid of it. Anyone have any suggestions?
Btw that video you posted is the same thing I had going up until today when it threw the CEL.
Good to hear you solved the issue.
Update time.
Yesterday I replaced the plugs with NGK Iridiums and checked all the plug wires. All of them were VERY clean surprisingly, so I just reseated them and reset the ECU. After resetting the ECU, the CEL remained, but when I took the car out, and the stutter was gone. I was hitting around 16-17psi and all felt back to normal.
Drove the car quite a bit today for work and everything was fine. After about 5-6 car starts, the CEL disappeared and I was beginning to feel relived that I found the problem.
When I left work tonight, I quickly noticed that the car felt low on power - Merging on the highway, the car only pegs about 12psi at WOT and then begins to creep upward to 15psi.
There's no CEL, and the stutter is gone.
Thoughts? Hunches? Bets?
