Suspension Is KW V2 for the Countryman Enough?
Old May 31, 2013 | 07:12 AM
preme123's Avatar
preme123
It can't be adjusted as much like the V3, but for money/value wise, is it good enough?
Is the fixed setup of the V2 suitable?
Or should I just save up and get the v3?
Thanks!
Old May 31, 2013 | 07:34 AM
Braminator's Avatar
Braminator
There is only one question to answer your questions.
What are your plans for your Countryman?
Old May 31, 2013 | 07:51 AM
preme123's Avatar
preme123
Right now I have the Michelin Super Sports on.
I'm planning on an ECU tune and that's probably it... around 220hp+-
Old May 31, 2013 | 08:10 AM
Braminator's Avatar
Braminator
Daily driver, occasional autocross, or just for looks?
Old May 31, 2013 | 08:11 AM
preme123's Avatar
preme123
Daily spirited driving. 1autocross a year? nahh probbably not, but i plan on one tho. hahahaha.
I'm planning to lower it by an inch too? Can the kw v2 lower the car?
thanks!!
Old May 31, 2013 | 08:31 AM
Braminator's Avatar
Braminator
Well you might want to check with KW as it looks like you can only get
KW Coilover Kit V3
KW Coilover Kit V3 Mini Countryman S ALL4 Learn More Part #: 35220096
Front Lowering:1.0" to 2.4" Rear Lowering:1.0" to 2.0"
IMO Coilovers might be to rough for you for everyday driving.
You might look into NM lower springs and new shocks.
Old May 31, 2013 | 08:34 AM
preme123's Avatar
preme123
KW Coilover Kit V3
As for the comfort aspect, it's adjustable, therefore it would be possible to make it as comfortable as stock?
How does the adjusting work? Turning ***** above the coilover or does it need to be removed? Can it be a DIY work? (Assuming I have little mechanic skill)
Old May 31, 2013 | 08:46 AM
Braminator's Avatar
Braminator
Check out this video on how to adjust Coilovers.. Then as far as it being a DIY, yes I feel it is but I am comfortable with working on my car. So if you have the tools and patience to work for 4-6 hours doing it, I say go for it.
Old May 31, 2013 | 09:43 AM
Koopah's Avatar
Koopah
preme123 --
You may also want to consider the Megan Coilovers referred to elsewhere in the "Suspension" forum. I believe they can be adjusted more than the K2s, are cheaper than the K3s, and can be adjusted closer to the "mild" side if you only want to lower and firm things up just a little. An independent MINI performance garage near me has done a number of Megan installs and I hear rave reviews.
FWIW
Old Jun 2, 2013 | 09:39 AM
Shoe Coupe's Avatar
Shoe Coupe
Originally Posted by Koopah
preme123 --
FWIW
RUN...dont walk from the NM springs. They bounce, theyre horrible. They'll give you a crap ride.
Old Jun 2, 2013 | 02:45 PM
cct1's Avatar
cct1
If you don't know what/how to adjust the V3's (specifically bound/rebound, height is relatively easy), and what each adjustment does, then don't get them. Especially if you don't know what you want for spring rates. The V3's are track oriented, and big time overkill for a car that will never see the track.
Get a good single adjustable coilover, with a stiffer spring rate than stock. Even that will be more than you need. You'll handle better, but the ride will be fine.
Old Jun 15, 2013 | 09:13 PM
praecurvo's Avatar
praecurvo
KW makes some of the best, most well engineered "Street Level" coilovers on the market. Their comfort in the softest setting is almost like a New Caddy. Tight and Supple. At mid-range and up, their aptitude increases for a superior handling road car.
You'll always hear me make a fuss about corner balancing, but if you pay the money for a great set of coilovers, what's another couple hundred to extract your co's maximum potential?
Aaron
Old Jun 16, 2013 | 06:20 AM
cct1's Avatar
cct1
Corner balance for the street? Overkill.
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
molala
Oct 2, 2015 01:53 PM
Sep 14, 2015 12:48 PM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
