R56 09 Cooper S tailgate issue
Old May 26, 2013 | 08:20 PM
Bedore's Avatar
Bedore
Greetings all,
Recently purchased a 2009 Mini Cooper S. What a great car! I have come across an odd problem and googling has produced some good information but I'd like to double check it here.
The trunk button on my key fob unlocks the rear tailgate and allows me to open it. However, I am unable to open it manually. I found a rubber area in the center of the tailgate that I believe is the switch, but when I press it nothing happens. Can anyone advise as to what is going on, and what the fix is?
Thanks all.
Old May 27, 2013 | 02:59 AM
Thor56's Avatar
Thor56
I had the same issue. I just bought a new one off outmotoring for $100 bucks. Bolts straight on and now works fine
Old May 27, 2013 | 04:11 AM
yetti96's Avatar
yetti96
Welcome! Sorry about the bum button. There is just a simple electronic switch under a rubber/weatherproof cover. The entire switch is replaceable and that sounds like what you will need to purchase and replace.
Old May 27, 2013 | 11:31 AM
Bedore's Avatar
Bedore
I took the 4 torx screws out and now I have a panel that is color matched to the car, that contains the license plate lights and the switch to open the tailgate. It all looks like one panel that does not seem to come apart. There is a plug that comes out of the tailgate that plugs into this unit. This unit appears to be sealed and I do not want to pry it open for fear of breaking it. Is this where the switch resides? Do I have to buy a whole new unit and have it painted to match?
Old May 27, 2013 | 06:21 PM
yetti96's Avatar
yetti96
I believe the whole panel comes off with a bit for force after the 4 torx are off. As far as the switch goes, you might see more screws once the painted piece comes off.
iggi
18
Feb 9, 2026 01:00 AM
phrza81
Oct 10, 2015 11:37 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
rphox2003
Aug 5, 2015 11:34 AM
