How To 1st Gen (2005 and later) Passenger Engine Mount Replacement
Old May 13, 2013 | 08:33 AM
woodstudio's Avatar
woodstudio
This is a summary of what I learned from other posts. I had an R52 with a passenger side leaking motor mount. I bought an aftermarket mount mini p/n 22 11 6 778 610 by Lemfoerder (Lemfoder). This mount is identical to stock with the exception that the word Mini is ground off and painted over. The mount was $63 (free shipping).
Special tools needed: e12 torx socket, 18 mm (or 11/16) socket.
1. Loosen right front wheel lugs.
2. Raise passenger side with jack and place jack stand or wooden blocks under mini subframe.
3. Remove passenger wheel (it really is easier this way).
4. Remove enough inner fender liner screws so you can pull the liner out of the way to easily reach the torx bolt.
5. Remove torx bolt from bottom of the engine mount.
6. Place jack with wood block under oil pan and very slightly lift engine.
7. Remove bracket grounding bolt with 13 mm socket. The bolt will fall if you are not ready to catch it.
8. Remove top nut of mount with 17 mm socket.
9. Remove (4) engine bracket bolts with 17 mm socket.
10. Remove engine mount bracket.
11. Remove engine mount bolt (to strut housing) with 18 mm socket.
12. Remove engine mount.
13. Clean area with isopropyl alcohol.
14. Assemble in reverse order.
Torque Specs (as best as I can find):
13 mm nuts- 10 ft lbs
17 mm nuts/bolts- 50 ft lbs
18 mm- 50 ft lbs
E12 torx- 50 ft lbs
Old May 13, 2013 | 09:24 AM
Braminator's Avatar
Braminator
Exactly like many of us have done. Great step by step. I bought the same mount awhile ago. No issues from mine.
Old May 13, 2013 | 12:09 PM
Nice write up.
Old Jan 24, 2014 | 11:51 PM
MINI4LJ's Avatar
MINI4LJ
Nice write up. I just used this and another post to replace mine. Made it very easy. I changed the belt while I had it apart.
Old Aug 3, 2014 | 02:43 PM
usafdrew's Avatar
usafdrew
Nice writeup. Used it with the help of some other resources for the engine mount replacement. A few things to note:
-That E12 torx bolt is a one-time use torque-to-yield bolt. Throw it away and buy another or risk it snapping when reinstalling. That bolt will also need to be torqued to spec plus 90 degrees of angle torque to initiate its stretch. For this you must use an angle gauge. The correct torque for that bolt is 41 ft/lb (plus the 90 degrees).
- The 16mm bolt to strut housing is 50 ft/lbs as is the nut for engine mount stud.
Old Aug 4, 2014 | 07:40 AM
The upper engine mount is right here.
Upper Engine Mount from 12/2003+ Gen 1 Upper Engine Mount 22116778610
http://www.ecstuning.com/Search/SiteSearch/22_11_6_778_610/
Superpro , linked above, also as a donuts shape dampener that mounts on top. Sandwiches between the top of the mount and the bracket.
Old Oct 3, 2014 | 07:01 PM
fastzombie's Avatar
fastzombie
How can you determine if the mount needs replacing? Mine looks like it is slightly compressed. I don't see any fluid leaking from it but it may be drained.
What do the 2004s use for a lower mount?
Old Oct 4, 2014 | 07:03 AM
mikeson's Avatar
mikeson
When mine was done, fluid leak all over and could tell right away.
If yours look clean, then I think it will be ok.
Mine was all mess by fluid leak.
Old Oct 6, 2014 | 07:51 AM
+1 on the fluid. It sometimes leaks down the back. But you will see a oily stain which is very hard to get off the engine bay rocker panel.
"What do the 2004s use for a lower mount?" Same lower Mount on all Gen 1 MINIs.
https://www.northamericanmotoring.co...any-ideas.html
Old Oct 7, 2014 | 07:32 AM
Swingerstunt's Avatar
Swingerstunt
I'm seeing a little variance on the size of the "Bolt to Strut Housing." I need this bolt, does anyone know what the size and threading is? I am having horrible problems getting in touch with the closest Mini dealership and they have already shipped the wrong bolts once.
Old Oct 7, 2014 | 07:55 AM
The bolt for the newest part is : 07119906199 M12X1.5X35-10.9
#4 for the 12/2003+ upper mount to side strut tower.
http://www.ecstuning.com/Search/SiteSearch/07119906199/
Old Oct 7, 2014 | 08:01 AM
Swingerstunt
ECSTuning you have made my day!
Old Oct 7, 2014 | 08:20 AM
Awesome !
Old Oct 7, 2014 | 08:53 AM
astroBlackMetallic_Mini's Avatar
where do i get another huge torx bolt for the mount? #5?
since its a "once time use" item... can i replace it with basically any similar sized bolt? a normal hex stainless steel one or something? or is there something special about the bolt itself...?
Old Oct 7, 2014 | 09:04 AM
Here is the new bolt #5: M10X125 torx head its a TTY bolt and is recommended to be replaced even though people sometimes reuse it.
http://www.ecstuning.com/Search/SiteSearch/22116766753/
Old Oct 25, 2014 | 04:56 AM
fastzombie's Avatar
fastzombie
I have replaced my mounts. Passenger side, lower and also transmission mount. After inspection they all looked rather worn. After they were removed it was really clear how bad they were.
One note: I did purchase a new torx bolt for the passenger side mount. When trying to remove the passenger side mount the torx bolt would not free up. Numerous methods were tried with no luck. Seeing as I had a new bolt, I used a dremel tool to cut the head of the torx bolt. Once the head was cut off the mount slid up and out.
Old Oct 27, 2014 | 08:08 AM
Fastzombie - glad you were able to get it done. having the extra parts does help. Soaking with freeall for a while helps.
Old Oct 27, 2014 | 12:58 PM
cristo's Avatar
cristo
Alliance Member
I'm curious. Has anyone ever had to replace the early mount
(up to 12/03, solid rubber)? Mine's still fine after 11.5 years.
silence2-38554
98
Sep 21, 2016 02:52 PM
silence2-38554
Nov 12, 2015 09:39 AM
maestro39
Oct 27, 2015 02:38 PM
mdutton11
14
Oct 26, 2015 01:47 PM
