R50/53 Help! Were can i get one
Old May 11, 2013 | 03:34 PM
R53minime's Avatar
R53minime
I accidentally broke the little nipple off of the tee that is on the far right this hose connects to the black cylinder on the left above the sc pulley then goes down below the throttle body anybody know we're I can get one or can I make it rubber vacuum hose?
Old May 11, 2013 | 03:35 PM
R53minime's Avatar
R53minime
It also runs right below the intercooler
Old May 11, 2013 | 03:37 PM
R53minime's Avatar
R53minime
You can see it right below the fuel line
Old May 11, 2013 | 06:21 PM
Braminator's Avatar
Braminator
Contact ECS.
Old May 11, 2013 | 08:32 PM
R53minime's Avatar
R53minime
I'm going to Monday.. I got my boost gauge working and with a 17% pulley and dt bpv I'm running 16 lbs my mini has 97,000 miles on it does that seem normal
Old May 11, 2013 | 08:34 PM
Braminator's Avatar
Braminator
Sounds about right.
Old May 11, 2013 | 08:42 PM
R53minime's Avatar
R53minime
Well I just got back and it is actually 17lbs
Old May 11, 2013 | 08:47 PM
Braminator's Avatar
Braminator
Like I said sounds about right. I bet you love it now.
Old May 11, 2013 | 09:00 PM
R53minime's Avatar
R53minime
Ya hopefully ecs will have that vacuum line it is rigged to work for now with regular vacuum line and some brass t fittings
Old May 11, 2013 | 10:10 PM
Da_Ghost's Avatar
Da_Ghost
You can run a vacuum line, my stock tube is actually on the floor right next to me :p I broke it a while ago, been running a vacuum line in the meantime. The part number is: 13907515434
http://www.realoem.com/bmw/showparts...=13&fg=15&hl=4
Old May 11, 2013 | 10:51 PM
R53minime's Avatar
R53minime
Man I could not find that for some reason thanks
Old May 12, 2013 | 12:02 PM
MINIdave's Avatar
MINIdave
You can also order any part you need for your car from your local MINI dealer's parts dept.... if they're not close, they will ship it to you.
Old May 13, 2013 | 05:01 AM
03EmCeeS's Avatar
03EmCeeS
I'll vouch for ECS Tuning here and say that they have some of the best prices for OEM parts. Between them and German Auto Parts you should be able to find everything you need.
