R56 Recommendations for driving lights:aesthetic look:non operational,will not wire in
Looking to possibly add driving lights(2) to my '11FJCW hatch. Want the look, don't need them to be operational. $640 for the OEM way too much. Appreciate the help. Thanks.
if you like the wipac's Seven has them for $60 plus shipping
http://www.7ent.com/products/driving...l#.UY1darWTjSg
and you can get brackets from Outmotoring.
http://www.outmotoring.com/mini-coop..._brackets.html
btw they are easy to wire up when you avoid the factory kit. Just run a simple toggle to someplace inside.... but I understand where you are comin' from. I installed the rear fogs - lens units only, no bulbs or wires, just cuz I did not like the filler plates in the tail..
took about 5 minutes . . .
while i can appreciate adding lights solely for the look......it seems pointless to not at least wire them up. especially if you are going through the trouble and expense of mounting them.
to do a simple wiring job, it should take even a novice no more than an hour to do.
that way, even if you never use them, at least youll have the option.
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
theateist
Aug 22, 2015 06:58 AM
