R50/53 2006 Mini Cooper Trans. into 2002 Mini Cooper
What is the difference between the two transmissions besides gear ratios? Will the 2006 mini cooper transmission work with the 2002?
Here are the two VIN's if it helps:
2006:
WMWRC33536TK72649
2002:
WMWRC33472TC37715
2006:
WMWRC33536TK72649
2002:
WMWRC33472TC37715
You could always change it to the 6spd Getrag like in the Cooper S if you are having problems.
See this http://personal.stevens.edu/~jdunn/F...heWeakLink.pdf
Check this thread out.
http://forum.minicooper.org/showthread.php?t=9643
From 2002-2006, the non-S Cooper had a 5 speed transmission (Midlands at first, Getrag later). The Cooper S had a 6 speed. With automatic, the non-S had a CVT transmission that was prone to spectacular failure, and the S had a standard 6 speed auto.
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 10, 2015 02:03 PM
