Replacing Your Brake Pads – Parts In Stock Now! By Pelican Parts
Replacing your brake pads is one of the easiest jobs to perform on your MINI. In general, you should inspect your brake pads about every 10,000 miles, and replace them if the material lining of the pad is worn down enough to trigger the pad replacement sensor. In reality, most people don’t inspect their pads very often, and usually wait until they See the little brake-warning lamp appear on the dashboard. It's a wise idea to replace the pads, and inspect your discs as soon as you see that warning lamp go on.
Check out our pad selection with multiple brands including Genuine MINI HERE
If you want to tackle this project on your own this weekend, we’ve created a great DIY article HERE
888.280.7799 | 6am - 5pm PST
PelicanParts.com
Aug 4, 2015 02:45 PM
