Water Pump Super Kits Ready To Ship by Pelican Parts
Old Apr 29, 2013 | 01:24 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Pelican is now pleased to offer our water pump super kits for the MINI. Is your car starting to run hot? Over time, the bearings in the water pump begin to wear, causing them to eventually fail and seize the water pump. With most of the MK1 MINI models reaching 150,000 miles or more, its not uncommon to see water pumps on their last legs. This kit includes everything you need to replace your old tired water pump with a brand new OEM unit. Here's what the kit includes:
Water Pump and Gasket
Thermostat
Thermostat Housing Gasket
12 oz. Redline Water Wetter Corrosion Treatment
1 gallon of OEM MINI Coolant (must be mixed with distilled water)
Expansion Tank or Thermostat Housing Cap
Upper and Lower Radiator Hoses
NOTE: In order to remove the serpentine belt, we reccomend using the belt tensioner tools PEL-NME5994 for base model Cooper models and PEL-NME5993 for Cooper S models.
Applies to: MINI R52/R53 (2002-08)
Kits in stock NOW for both manual & automatic transmissions!
Manual: $ 274.20
Auto: $ 267.70
Purchase HERE:
http://www.pelicanparts.com/catalog/...PRJ022_pg1.htm
888.280.7799 | 6am - 5pm PST
Cereall
Sep 5, 2019 06:05 PM
KrisMiss
Jan 3, 2016 02:02 PM
kpl
Aug 11, 2015 04:52 AM
kwijmbo
Aug 5, 2015 09:00 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
