R60 Lowering springs and sport mode
Old Apr 28, 2013 | 07:44 PM
'Roy Vernon Zumwalt's Avatar
'Roy Vernon Zumwalt
if this is on another thread, I couldn't find it. Im still trying to figure out how a mini operates. I was told that hitting sport mode tightens up suspension, gears, ect.. does lowering springs effect sport mode at all? Im still under warranty, does lowering springs effect it at all?
Old Apr 28, 2013 | 07:53 PM
Braminator's Avatar
Braminator
It changes shift point on the transmission , it basically keeps the revs up so you are more in the power band. It also tightens up the steering as I am sure you have felt and changes the accelerator pedal ratio (throttle by wire) for quicker response.
As far as lowering your MINI, that will not effect your warranty. Don't let the dealer bully you into thinking it will. There is a law to protect you called http://en.wikipedia.org/wiki/Magnuso...s_Warranty_Act
Old Apr 28, 2013 | 07:59 PM
bmwr606's Avatar
bmwr606
the sport button does NOT change any suspension settings nor does it increase engine power
what it does do is
1) changes the engine response to throttle pedal movement ...
with the sport button off, the throttle pedal is "linear", 1/4 pedal movement gives 1/4 throttle opening ... with the sport button on, the throttle pedal is "progressive", 1/4 pedal movement gives 1/2 throttle opening
these may not be the exact numbers, but you get the idea ... it makes the car feel faster
2) it changes the amount of power assist the power steering gives, off = more, on = less
3) if you have an automatic transmission, sport button on raises the shift points and how the transmission responds to throttle movement ... sport button off, if you lift off the throttle, the transmission will upshift, sport button on, it will hold in gear ... i have heard that it will not use 6th gear with sport button on, i have a manual so can not confirm that
scott
Old Apr 28, 2013 | 08:00 PM
'Roy Vernon Zumwalt
cool, thanks.
Old Apr 28, 2013 | 10:31 PM
Hujan's Avatar
Hujan
what it does do is
scott
It does use 6th on the auto in Sport mode. Otherwise, you nailed everything, Scott.
Old Apr 29, 2013 | 04:54 AM
Braminator's Avatar
Braminator
hmmmm
Old Apr 30, 2013 | 07:27 AM
dpd2012's Avatar
dpd2012
Apologies if this is a dumb question... what is the point of decreasing the power steering assistance when sport button is on? Is it just a cosmetic thing?
Old May 1, 2013 | 05:37 AM
ludrof11's Avatar
ludrof11
With decreasing the power steering with the sport mode on, it makes the steering firmer so it is easier to control
melscoop
Mar 30, 2016 06:56 PM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
xpunisherx
Aug 10, 2015 10:50 PM
