R56 Alta air filter oil.
Old Apr 27, 2013 | 06:39 PM
sirr6's Avatar
sirr6
Is it safe to use k&n oil filter on the alta intake filters? The site states they sell uni brand and can be found at most bike shops. I did buy the cleaner but the oil.
Old Apr 27, 2013 | 08:38 PM
Braminator's Avatar
Braminator
You can not use the K&N filter oil on a foam filter. You need one designed for foam filters. You can use these as they are found in most cycle shops
http://www.belray.com/bel-ray-foam-filter-oil
http://www.motorcycle-superstore.com...ilter-Oil.aspx
Old Apr 27, 2013 | 09:03 PM
sirr6's Avatar
sirr6
Ok thanks for the info. I did use the k&n so I'll clean it off tomorrow. I did drive it around the block, is that ok?
Old Apr 28, 2013 | 12:35 AM
ZippyNH's Avatar
ZippyNH
K&n filter oil will destroy/degrade the foam....
Clean it ASAP. You will notice when you apply the uni oil, it is VERY different stuff.
The single most important thing with filters that get cleaned and oiled is to follow the directions....the oil is used pretty sparingly...more IS NOT BETTER. Excess oil will cause sensor issues....
Old Apr 28, 2013 | 12:47 AM
sirr6's Avatar
sirr6
Thanks for the info. I cleaned the k&n oil already, should I clean it again? As for the oil the above post from bram states to use the pj1 oil. I got the cleaner from my local bike shop, is that oil ok also?
Old Apr 29, 2013 | 07:00 AM
Mini2na's Avatar
Mini2na
Just make sure it is made for FOAM. It does not matter what brand you buy.
Again, more is not better. The oil is pretty sticky.
Old Apr 29, 2013 | 07:46 AM
sirr6's Avatar
sirr6
Got the uni brand thanks guys! Now if only someone can help me with my thread I just posted in the stock/issues section.
Aug 27, 2015 03:18 PM
theblackfalcon
Aug 26, 2015 09:18 AM
gkp
Aug 26, 2015 07:18 AM
polotska
Aug 23, 2015 09:10 AM
Aug 21, 2015 08:44 AM
