R50/53 I need help!
Old Apr 22, 2013 | 07:38 PM
R53minime's Avatar
R53minime
I need help!
I just went to return some movies and when I turned around I noticed some smoke coming from the grill I popped my hood to notice I had a bit of oil in the coils of the radiator so I look down by the alternator to notice oil all over the place there is a bunch below on the plastic some up on the alternator just about everywhere in that area any idea were this might be coming from?
Old Apr 22, 2013 | 08:22 PM
Johnna's Avatar
Johnna
Hard to say for sure but there is a crank sensor in that area. The crank sensors are prone to leaking due to failing o-rings. When they start leaking, it's usually a slow leak that weeps down the front of the engine a bit to the right of center. Your leak sounds more drastic than that. Let us know what you discover.
Old Apr 22, 2013 | 08:29 PM
R53minime's Avatar
R53minime
I just got the car back from Carmax about 2 weeks ago due to a oil pan gasket leak but since then I have put on a 17% pulley I may just take it back to them and hopefully they don't say anything about it
Old Apr 22, 2013 | 10:37 PM
Tab32's Avatar
Tab32
Did you change your oil filter recently? Could be a broken gasket.
Old Apr 23, 2013 | 05:33 AM
R53minime's Avatar
R53minime
Yes they did the oil filter when they did the pan gasket but its the front corner of the motor near the belt and the supercharger
