R56 Rub noise backing up
07 MCS manual. For the past few days when I back out of the garage it makes what sounds like a metal on metal high pitched squeak. It's continuous and I think it continues after I disengage the clutch. No noise going forward, and if I stop and back up again nothing. Just first thing in morning. I only back up about 15 yards so I can't tell how long it lasts. Had the front brakes done last year. Ideas?
i bet it is the brakes ... mine does it to, but only in reverse and only until i apply the brakes
try this ... back into your garage so you pull out forward ... stop by applying the brakes then back up
if i do that, no noise backing up
scott
scott
Is your handbrake engaged while parked? Try leaving it off one night to see if it continues.
Has it been wet weather? sometimes I get noise if it has been wet and the disc plate developes a bit of rust.
I left the handbrake off in the garage, and this morning it squeaked backing up. I think it's the brakes, maybe fronts. I'll back in tonight and go out forward tomorrow and see. I'm due for an oil change/rotation locally (not dealer) I could have the dude who did the brakes take a look too. Thanks!
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
Oct 24, 2018 01:20 AM
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
