R50/53 Air blowing into cabin at freeway speed
Old Apr 17, 2013 | 07:45 PM
Brianjager's Avatar
Brianjager
I posted about this a while back.
Problem is, when I'm traveling at freeway speeds (above 50mph) I notice a rushing air sound in the cabin. It's super loud! At first I thought this was the blower motor contains to run even when off. Matter some experimenting, I've determined that's not the case. It's actually air blowing in through the vents. I'm thinking that the flap letting in air from outside is not closing all the way?
Is this a normal function? Or do I indeed have a problem?
How loud is your mini in the cabin?
Old Apr 17, 2013 | 08:08 PM
Boosty's Avatar
Boosty
I noticed I had this problem once comming home from work, I hope you figured it out cause my mini more than likely has the same problem
Old Apr 17, 2013 | 08:26 PM
ZippyNH's Avatar
ZippyNH
One thing you will notice oin the MINI, it does not have a separate side vent for only fresh air...
If the climate comtrol system is OFF, air will still flow...
heck, I often set the temp....then turn the fan off...it is NORMAL.
If you do not want fresh air getting into the car, pres the resculate button in, then turn the fan off...
The WINDOWS will fog up FAST..the TINY interior volume of the MINI will not hold much moisture from your breathing...so it is not really much of an option...hense the fact it defaults to open to let a bit of fresh air in to prevent fogging!!
Old Apr 17, 2013 | 09:04 PM
Brianjager's Avatar
Brianjager
Thanks ZippyNH.
When you say "press the recirculate button in" should it be lighted up or not? Also, is it a single press, or a hold down?
Old Apr 17, 2013 | 09:39 PM
Eric_Rowland's Avatar
Eric_Rowland
Lighted. Just press.
Old Apr 18, 2013 | 01:26 AM
Boosty's Avatar
Boosty
I've actually been doing the same thing zippy , setting the temp than turning off the fans.
rob&JCW
Feb 13, 2023 07:03 PM
W0TM8
Dec 19, 2019 07:50 AM
Beau B
12
Aug 24, 2015 01:50 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
